Predator Ball Joint Removal
Old Nov 15, 2003 | 08:38 AM
jsyi's Avatar
Default Predator Ball Joint Removal
Whats the best way to go about doing this without damaging it?
Old Nov 15, 2003 | 09:59 AM
quadwrench's Avatar
I have not done any Preds, but looking at the parts diagrams - it's very similar to other makes.
To remove the knuckle, disconnect the shock, remove the upper and lower ball joint nuts - take 2 good sized hammers - place 1 on the bottom front part of the knuckle where the ball joint goes through (acts as a backup), use the other to hit the rear side part where the ball joint goes through (you can switch around if swinging area is better from the front) - the ball joints are tapered and this will "pop" them out, but it make take a few swings to accomplish. Removing the wheel hub and rotor may make it easier to access.
Do the same for the upper ball joint. They do make a tool to "press" the ball joints loose from the knuckle if you want to spend the money (it only works on 2WD quads)
If you are changing the ball joints - remove the arms, I use a hydrolic press and a set of 3/4" drive sockets to find a size that the ball joints just fit inside - press 'em out, press the knew ones in. Don't forget there is a retaining ring holding the ball joint in the arm.
Old Nov 15, 2003 | 10:22 PM
jsyi's Avatar
K thanks man. I need to get em out[img]i/expressions/face-icon-small-smile.gif[/img] I tried taking a set out before by pounding the crap outta em but i ended up ruinin the thread
89Lt250r
Sep 7, 2015 07:53 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Jason Richards
Sep 4, 2015 06:17 PM
toonces
Aug 12, 2015 06:42 AM
musselmark
Jul 17, 2015 02:40 PM
