Cam set-up
Old Nov 16, 2003 | 02:38 PM
fastasyoucango's Avatar
Default Cam set-up
Ok. I got a stage 1 hot cam for my 400ex. I'm going to be running a JE 11:1 piston (416cc). Head hasn't been milled. Now, a couple of questions. Should I worry about checking for valve to piston clearance? I can't run the factory decompression assembly on the new cam, do I really need it? Thanks in advance.
Old Nov 16, 2003 | 06:19 PM
420EX's Avatar
Default Cam set-up
you wont have to worry about the valve to piston clearance, that has already been considered in the machining of the cam. the decompression mechanisn helps with startup bu now you will most likely have to use the choke.
Old Nov 16, 2003 | 08:01 PM
Default Cam set-up
Thanks for your help [img]i/expressions/face-icon-small-smile.gif[/img]
Johnny Mac
Aug 15, 2019 03:13 PM
MattFL
Nov 20, 2001 02:36 PM
Todd400
Sep 25, 2001 11:58 AM
prairie633
Jun 4, 2001 02:44 PM
