scram 500 off idle stumble
Old Nov 16, 2003 | 08:05 PM
danny13's Avatar
Default scram 500 off idle stumble
i have a 98 scrambler 500. Its got an off idle stumble. I have the hot seat performance kit with the pipe, 160 main jet, k&n filter, and clutch kit. I am way down on power. I rode a stock 2000 scram 500 and it felt way faster. Then i got beat by a 500 sportsman by about 3 quads out of the hole.
Any ideas? It was doing this before i put the kit on. I was hoping that would help out.
Old Nov 16, 2003 | 08:22 PM
Hozed's Avatar
something aint right if the kit made you loose power...
Old Nov 16, 2003 | 08:26 PM
RookWV's Avatar
Is a 1998 Scrammy the 500HO engine? If not, that would be a big difference....supposedly 20% more power in the HO
If not, you might need to change weights on the clutch....
Are you sure it's a 160 main?
Old Nov 16, 2003 | 11:20 PM
scrambo's Avatar
You may also need to check your belt or the buttons in the secondary clutch. I'm told this can cause the hesitation on starts.
Old Nov 17, 2003 | 12:35 AM
BigBadScrambler's Avatar
Yes, check the clutch buttons. HPD makes some nice replacement aluminum buttons. Also make sure that you wound the secondary clutch 1/3 turn
Old Nov 17, 2003 | 06:14 PM
danny13's Avatar
How do i check my clutch buttons? Also if i hold it just above idle then gas it, it revs fine.
Old Nov 18, 2003 | 12:48 AM
The clutch buttons are in the secondary clutch. They are what ride against the helix.
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
