removing starter on 86 tb250
Old Nov 18, 2003 | 12:17 PM
myndphaser's Avatar
Default removing starter on 86 tb250
Rebuilt the motor with new rings, seals, and gaskets. Still having some clutch problems though. Considering pulling the starter and making it a push start only.
Does pulling the starter off make the tb250 easier to push start? For whatever reason right now it's difficult to push, and will pulling the starter remedy that?
Old Nov 18, 2003 | 12:43 PM
fishslab's Avatar
I don't think you can push sart one of these things. The belt would most likely slip throught the clutches before it would ever push start. Do you have a recoil starter as well as electric start?
Old Nov 18, 2003 | 01:05 PM
myndphaser's Avatar
It has a pull start, but the clutch never releases tension from the belt. Pull starting won't work because I can't engage the clutch to put it in gear. That's why I was wondering about converting to a push start only machine.
Old Nov 18, 2003 | 11:38 PM
fishslab's Avatar
My guess is you need to get it to release the belt from the drive clutch. This is where your problem is at the present moment. The belt should ride freely until the clutch engages. It may just need some good cleaning to get it to open up all the way.
ghost civic
Jan 15, 2020 07:43 AM
ghost civic
Jul 27, 2015 03:15 AM
ghost civic
Jul 19, 2015 10:13 AM
Desimation2k8
Jul 17, 2015 12:37 AM
ghost civic
Jul 15, 2015 10:48 PM
