Tires for Sportman 600
Old Nov 18, 2003 | 08:28 PM
CATTech's Avatar
Default Tires for Sportman 600
Could someone let me know what the largest tire you can put on this quad without a lift or rim replacement? This is my brothers quad and he wants to put some ITP 589's on it.
Thanks
Old Nov 18, 2003 | 09:47 PM
400sp's Avatar
i have 26 inch 589s on itps c-series rims 0on my 04 sp600 with no lift kit, they do rub just a touch when i jump it, these tires hook up great, i also added a dalton clutch spring kit on it to
Old Nov 20, 2003 | 01:15 AM
MNSPORTSMAN's Avatar
First , you must remember that all 4 tires must be the same height. 25,26,27,etc.
Second , I just put titan 589 MT/AT on my 03 600 sportsman.
Rears are 26x12x12 and have no clearence problems.
Fronts are 26x9x12 and i had to put flat washers of "EQUAL " size on all the wheel studs and then put the rim on. This allows clearence between the tire and tie rod end. Otherwise it will rub and destroy the tie rods !
When you order 25 inch tall tires , the lug depth is not as deep. Order 26 inch or taller tire
and you will get the deeper lugs.
My third opinion is , if you go taller than 26 inch , the tires on the front will rub on the front fender and fender extension twords the rear by the foward part of the footwell.
I got my titan 589 AT/MT tires from nebraskatire.com. They are cosmetic blems . The web site says $45.00 each. My dad picked them up in person and they were only $ 35.00 each for any size tire ! They are 6 ply. Almost 2 inch tall lugs. The titan name had been groud off the side wall because of franchise rights. The rim sits in the bead about 1/2 inch to protect the rim from dings.
The tires are very nice and cheap ! $ 140.00 for 4 tires.
Hope this helps out.
Old Nov 20, 2003 | 01:19 AM
I forgot to mention. My titan 589 AT/MT tires are blems and are mounted on STOCK RIMS.
Also, with the 27 and 28 inch tall tires, if you have weight on the front of the machine such as a load on the front rack or a plow set up , this will cause aditional clearence problems.
Old Nov 20, 2003 | 01:30 AM
MnFriesen's Avatar
mnsprotsman...what was the time for your Camaro? you said you would post 1/4 mile times "later this summer" and according the weather...we are suppose to be gettin a snow storm in south east minnesota...think summers over lol...but then again you never know in minnesota
Old Nov 20, 2003 | 03:03 PM
I HAD TO HAVE ROTATOR CUFF SURGERY THIS SUMMER SO CAMARO PROJECT WAS PUSHED BACK.
MAYBE THIS COMMING SUMMER IT WILL HIT THE TRACK . HOPE YOU FOUND THE RIGHT TIRES !
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
