can't keep 400 polaris cool
Old Nov 20, 2003 | 01:45 AM
DRod's Avatar
Default can't keep 400 polaris cool
hey guys and gal's ,
I can't get any help from the polaris guys. I was wondering if any of you motor heads can help me. after about 20 minutes of riding my 400 starts to loose power and overheats. This is what I have tried so far but I must be missing something.
[img]i/expressions/face-icon-small-blush.gif[/img]
I have checked for flow (that's ok) Have checked level of colant(ok) checked both lines in and out of engine/rad. (ok) and have bled out the system with that pee hole on top of head. (just let colant come out and closed ) I have also checked for air bubble in rad while the machine was cool to see if I had a cracked head.(looks ok)
any Ideas? Thanks
Old Nov 20, 2003 | 12:48 PM
jeff1989's Avatar
Is your fan coming on? I had that problem with my 400 sport. The fan went bad.
Old Nov 20, 2003 | 12:59 PM
Bubba297's Avatar
That's what it sounds like, but you need to give more info. Is the motor modded or stock and what has been done? Has the jetting been touched? Fill us in as one missing part of info could be the answer.Bubba
Old Nov 20, 2003 | 06:28 PM
ftwflh's Avatar
Have you cleaned the fins out of the radiator,check the fan motor,and made sure there isnt an intake leak.
Old Nov 20, 2003 | 06:49 PM
RookWV's Avatar
Yes, those fins can get all mucked up and not allow any air flow through....take the front grill cover off and take a water hose (nothing high pressured) and just keep spraying (preferably back to front) until it run clear....I spend a good 5 minutes on my radiator after I've been riding through mud bogs...
Old Nov 22, 2003 | 04:01 AM
DRod's Avatar
Thanks for all replys. I have not done anything to the engine it's all stock.
the only thing different was I took the machine from 8600 feet to 11500.
The more I think about it the more I think it's the fan. does anybody know how to check the sensor to the fan?
Old Nov 22, 2003 | 07:08 AM
ftwflh's Avatar
When you change evavations you change the air mixture in the carb.You need to rejet your carb for the higher evavation.
Old Nov 23, 2003 | 10:52 PM
Quadzilla1000's Avatar
If the fan checks out good it sounds like you may have a blown head gasket that happen to me and i found it to be a blown head gasket!
bzdok1234
30
Feb 23, 2016 01:55 PM
clsharky
Jul 13, 2015 02:07 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
