Trailblazer Timing???
Old Nov 22, 2003 | 11:02 PM
2manytoys's Avatar
Default Trailblazer Timing???
Ok this is something I have not checked since new and with all the mods. How do I check it? Where should it be and would this help the lag from take off?
Old Nov 23, 2003 | 01:13 PM
talonhawk's Avatar
I don't know if it will help, thats for the Polaris gureu's to say.
The stock Ignition timing is 25 degress BTDC @ 3000 RPM +/- 1.5 degress.
The inspection hole is in the starter recoil/ magneto housing.
If you are going to reset the timing:
1. Remove magneto housing
2. Remove flywheel
3. Loosen stator plate & adjust stator plate position.
Clockwise retards ignition and counter clockwise advances the ignition.
The book says to check the position with a room temp. at or around 68 F
and to NOT let the engine run and warm up because a warm engine
will retard approx. 2 degress.
Old Nov 25, 2003 | 02:34 AM
Iggysoil's Avatar
Ya straight from the book.
However I found that if you have the flywheel lighted the timing marks maybe gone. All you can do is removed the flywheel, puller required, and check the markes at the stator plate.
slowgsxr97
Mar 18, 2022 03:40 AM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
shewshew989
Jul 14, 2015 03:09 AM
shewshew989
Jul 14, 2015 02:54 AM
