engine break-in
Old Nov 24, 2003 | 10:34 PM
badazzpred's Avatar
Default engine break-in
my>? is once you start the break-in procedure as per manual instructions can you start on it one day and finish it the next or is it best to break the engine in all at once can anyone elaborate thanks...............................
Old Nov 25, 2003 | 12:34 AM
badazzpred's Avatar
would someone be able to answer this sorda stupid >? for me I just want to make sure its done correct Im also looking for any websites pertaing break-in procedures
Old Nov 25, 2003 | 01:04 AM
trailrider500's Avatar
Ok i think it would be ok to break it in over a few days... Here is a web site should help you... BREAK IN
Hope this helps....
Old Nov 25, 2003 | 01:18 AM
badazzpred's Avatar
trailrider thank you this is what im looking for this kind of information from well known reputable sources
Old Nov 25, 2003 | 05:13 PM
Anytime.....
Old Nov 25, 2003 | 07:26 PM
scramblered's Avatar
the biggest problems when braked-in a new engine is the normally hotter heat produced by the tight motor parts,,keep an eye on coolant as well
and leak possible,,the way you ride it at this moment will determine the way it should perform later,,,take it easy as it was the first time ever you ride a quad and most important let it cool at 20-30 min interval.changing regulary the motor oil til the brake-in time is done also help.a 4 stroke take longer than a 2 stroke so let it drink his gas slowly.on a brand new engine normally it is better to let it idle some time before go riding to be sure coolant is well sealed and trough the whole system.
Old Nov 27, 2003 | 02:53 PM
badazzpred's Avatar
thanks scramblered for the advice
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
austinwhitton
Aug 11, 2015 06:21 PM
Jul 30, 2015 09:39 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
