Water in swing-arm bearings
Old Nov 24, 2003 | 11:19 PM
Sandtrax690Raptor's Avatar
Default Water in swing-arm
This may be a stupid Q??? but is there anything that I need to do after riding in water several time as maost of the time I cross the river the water is above the swingarm.
Old Nov 25, 2003 | 12:35 AM
warrior007's Avatar
Default Water in swing-arm bearings
I use anti seize to lube my swingarm bolt, it works very well. I like to occasionally remove the bolt (very easy, once a month) lube it up with anti sieze and put it back in. Anti sieze doesnt dry out and gum up like grease.
Also try not to power wash the area of any bearings, water will get in quicker that way then deep water crossings.
Old Nov 25, 2003 | 12:52 AM
Treeshot's Avatar
You might think about wheel bearing grease used for boat trailers. It has a very high water resistance.
wendal
Aug 3, 2024 10:03 PM
2quiker
Mar 22, 2022 08:36 PM
Customer Service #1
May 15, 2020 08:46 AM
panicmanic
Sep 28, 2015 12:59 PM
Elkaholic
Sep 6, 2015 02:44 PM
