trail tech speedo
Old Nov 24, 2003 | 11:44 PM
madmedic's Avatar
Default trail tech speedo
Does anyone have any input on the trail tech speedo? I just ordered one and was wondering if they work well and how hard it is to install?
Old Nov 24, 2003 | 11:47 PM
95Wolverine's Avatar
I guess the install depends on what it is you are mounting it on.
My install was trickey as they do not make a kit for a wolverine. I ordered one for a warrior and drilled a hole in the brake rotor and then used a centerpunch to lock the magnet in place.
As for functionality, I like it. Once calibrated, gives as good a reading as a factory Honda speedo. The miles added up the same for all 83 miles ridden.
Old Nov 24, 2003 | 11:48 PM
madmedic's Avatar
Thanks, It's going on an 04 raptor.
Old Nov 24, 2003 | 11:56 PM
Looks as simple as changing out a rotor bolt and drillin a hole.
Simple.
http://www.trailtech.net/raptor.htm
Ride On.
Hardest part is deciding how to mount the actual speedo
Old Nov 25, 2003 | 10:11 AM
Dfitz's Avatar
I have the handle mount very easy to install. The directions want you to get rid of the disc brake protector, but I made it work with it on. I just have to get the speedo right. I didn't calc it correctly so it said my top speed was 109. Maybe I should just keep it this way.
Old Nov 25, 2003 | 11:03 AM
Just4Kicks's Avatar
I installed one on the wife's Warrior. Pretty easy to install and gives accurate enough readings if calibrated properly. Not real user friendly though IMO. I have to get the directions out everytime I want to change something. Still, it's a good product overall.
Old Nov 25, 2003 | 02:18 PM
NLWarrior01's Avatar
I don't think you even have to drill putting it on a Raptor. My kit came with a special bracket for mounting the sensor on a Raptor.
If you're mechanically inclined at all you should have it installed in under an hour providing you have the tools on hand. I was about 1.5 hours on my Warrior, but I had to go to the local tool shop to buy an M6 allan socket to remove the rotor bolt.
Hardest part of it all is programming the computer [img]i/expressions/face-icon-small-happy.gif[/img]
Old Nov 25, 2003 | 02:33 PM
Dfitz's Avatar
NLWarrior01, Are you runnuing stock front tires if so what # did you put in for MPH?
Old Nov 25, 2003 | 02:51 PM
Yeah I got stock fronts, though they're worn a bit. I measured them to be about 21.75" in diameter, giving a circumference of 1735mm.
The basic configuration for the trail tech is for km/h, but you can switch it near the beginning of the setup to mph. I'm in Canada, so I left it as km/h.
Ramman1
Aug 11, 2022 01:53 PM
Adrian Turner
Aug 30, 2015 04:08 PM
Technical and How-To Articles
Aug 21, 2015 09:31 AM
maxjung
Jul 23, 2015 08:37 PM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
