sparkplug recommendation
Old Nov 25, 2003 | 03:27 PM
fastasyoucango's Avatar
Default sparkplug recommendation
I got my 416 running finally. I've having problems with cold starting. I keep fouling the plug out. Is there a better plug I can use to help this. I even went down on the jetting, but it still does it. I'm currently running a NGK-R.
Old Nov 25, 2003 | 08:58 PM
dragracer789's Avatar
Try a hotter plug...
Old Nov 26, 2003 | 02:30 AM
cals400ex's Avatar
ross and je says the colder plugs are a must with their pistons given they are higher compression than stock. list your mods, your jetting, temp, and altitude. i actually run the colder plug most of the year. when winter comes, i put in the stock plug. do you run an ignition box??
Old Nov 26, 2003 | 08:43 AM
416cc JE 11:1 piston, stage 1 hotcam, port and polish, K&N filter, White Bros E-series pipe. Jetting was a 170 jet, now it's 165. This is from a dynojet jet kit. I'm not sure on altitude, but it's below 5000 feet, I'm sure. Temp between 30-50 degrees. Hope you can help [img]i/expressions/face-icon-small-smile.gif[/img]
wendal
Sep 7, 2019 06:46 AM
bigred20653
Oct 2, 2015 10:05 AM
kampswas
Sep 23, 2015 05:05 AM
Jersey General
1) Engine problems..
Sep 13, 2015 01:05 PM
Brandon400
Sep 5, 2015 08:44 PM
