hub fluid
Old Nov 25, 2003 | 07:10 PM
Scramblerman03's Avatar
Default hub fluid
Is the front 4x4 fluid from Polaris Pure Polaris Premium Demand-Drive Hub Fluid?
Old Nov 25, 2003 | 07:11 PM
trailrider500's Avatar
Default hub fluid
Yeah thats the stuff...
Old Nov 25, 2003 | 09:23 PM
highwayman's Avatar
Default hub fluid
A lot of people use Mobile 1 synthetic ATF because it seems to work better, I know that when I changed to ATF I had less front wheel drag. ATF is not much cheaper than stock and the price was not a factor because of the small amount used. If you do a search for hub fluid you will get lots of info on using ATF. I change hub fluid 3 to 4 times a year it is very easy to do.
Old Nov 25, 2003 | 11:01 PM
BigBadScrambler's Avatar
Default hub fluid
I too use Mobil 1. I found that it prevents the armature plate from sticking a lot better. Thats JMO. To each his own[img]i/expressions/face-icon-small-cool.gif[/img]
Old Nov 25, 2003 | 11:27 PM
fishslab's Avatar
Default hub fluid
Scramblerman03,
Are you talking about the hubs or the differential?
Old Nov 25, 2003 | 11:38 PM
Default hub fluid
The hubs cause it's starting to engage when out of 4x4 and I havn't changed the fluid.
MaasaiMomma
Mar 25, 2021 11:24 AM
hueby
Nov 6, 2015 11:34 AM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
Technical and How-To Articles
Aug 21, 2015 09:31 AM
rcappie4
Jul 10, 2015 04:54 PM
