locking an atv?
Old Jun 19, 2000 | 03:51 PM
ordway1's Avatar
ANYONE HAVE ANY GOOD SUGGESTIONS ON HOW TO LOCK AN ATV IN THE BACK OF A PICKUP?????????????
Old Jun 19, 2000 | 04:33 PM
trx430ex's Avatar
substitute one of the bed mount bolts with a 5/8 two inch eye hook and chain through. mount with one nut on top washer,then bed washer and nut= nylock
Old Jun 19, 2000 | 05:52 PM
BigRed450's Avatar
Don't forget to use G7 high grade chain (can't be cut with bolt cutters) and high grade bolts. If they're gonna try and steal it, make 'em work for it.
Jeff
Old Jun 19, 2000 | 06:02 PM
THEXOTIC1's Avatar
Not sure if this will work for you bike but i bought a master lock ladder rack lock from home depot and slipped it through the sprocket and then through the rear rotor and lock it. They will have to carry the bike if they want it.
Old Jun 19, 2000 | 10:30 PM
Tree Farmer's Avatar
Locking the axle is a good idea; however,
I'd add a hardened chain, or something like Kryptonite "Barbed Wire" cable, TheExoticOne; because: if they want it, they WILL carry it. Kryptonite manufactures a "Disc Lock" with a coupling to a length of looped "Barbed Wire" cable. The intended use is on motorcycles with disc brakes; the lock goes through the disc, while the cable is looped around a fixture like a light pole. This rig can be easily adapted for truck bed and quad applications.
Tree Farmer
Old Jun 19, 2000 | 10:48 PM
THEXOTIC1's Avatar
True if they want it they will carry the bike. How about the trailer lock mod and addapt this to a pick up bed. I looks like a club for a car and hooks on the frame and on a bracket that is mounted to the trailer or truck. I saw this once in the back of a dirtwheels mag. I saw the caliper lock for mainly street bikes. they are $30-$40 the one at home depot is only $18 and is biggger. Just a little added security. This runs in my rear axle and through a larger eye bolt that is mounted to the concrete floor. And i also lock up all ocy/acy tank regulators and saws dont want to make it too easy.
greg74
Sep 10, 2019 03:03 PM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
Findlay Tulloch
Aug 25, 2015 05:00 PM
