warrior axle
Old Nov 25, 2003 | 11:24 PM
Warrior350ripper's Avatar
Default warrior axle
can sumone tell me how to tightin it
Old Nov 25, 2003 | 11:50 PM
87Banshee250sx's Avatar
Get a huge wrench (pipe wrench or gargantuan adjustable) and righty tighty. Its easy to have some one hold the rear brake on while u do it. Just tighten the inside one first then the outside one second.
-Nick-
Old Nov 29, 2003 | 02:28 AM
okay i loosened the first nut .............any triks for the second one it doesn't wanna g0[img]i/expressions/face-icon-small-sad.gif[/img]
Old Nov 29, 2003 | 12:10 PM
???[img]i/expressions/face-icon-small-confused.gif[/img]
Old Nov 30, 2003 | 10:13 AM
shall36's Avatar
What are you trying to do, just tighten up the axle? The manual shows the two nuts on the axle. You're going to have to hold the inner nut while tightening the outer nut. It's calling for 140 ft.-lb. of torque, which is quite a bit. The manual also shows a special tool fixture to tighten these nuts, but I would assume that a pair of thin wrenches will work. You could try a pair of big adjustable wrenches, but you probably won't be able to get enough torque on them.
Does this help?
Old Nov 30, 2003 | 01:28 PM
the second nut doesn't wanna get loose even with the bike in gear brakes pressed and someone sitting on it nut still won't loosen wtf?
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
1000gade
Sep 9, 2015 04:41 PM
