Diagphram Spring????
Old Nov 27, 2003 | 12:36 PM
caliraptor's Avatar
Default Diagphram Spring????
As I mention on a previous post, I found out I have a broken diagphram spring in my right carb...this spring is under the black cover on the top part of the carbs. Looks like it keeps pressure on the needles, not sure though. Will a broken spring cause poor performance? Because I was trying to go up a dune at Gordons Well and couldnt, when I finally made it (going a bit sideways) a 400ex made it up at the same pace I did [img]i/expressions/face-icon-small-mad.gif[/img] Any one know?
Old Nov 27, 2003 | 01:06 PM
Ernie660R's Avatar
Yes it will, the carb with the broken spring was allowing more fuel into the carb causing a rich condition. Replace them with a new set of two of get Dynojet springs, I used them and they workrd well.
Old Nov 27, 2003 | 01:46 PM
caliraptor's Avatar
Would it be ok if I used the stock springs? I ordered 2 from Yamaha, but if the DJ are better, I will just buy those instead.
Woop!! Wooop!!! Im a PRO RIDA!!!!![img]i/expressions/face-icon-small-cool.gif[/img]
Old Nov 27, 2003 | 02:13 PM
sixsixT's Avatar
Was it the big diaphram spring or the little one under the plug that holds the needle? Either will cause it to run bad but the bigger one would be worse.
Old Nov 27, 2003 | 02:15 PM
caliraptor's Avatar
the big long one...like 4-5inches..as soon as you take off the black round cover, the spring comes out, thats the one Im talking about.
Old Dec 2, 2003 | 08:37 PM
caliraptor's Avatar
Parts came in today, will install two new diagphram springs (one in each carb) and will let you guys know if that fixed my problem
shimanok2
Jan 29, 2016 07:37 PM
brinkkl2000
Oct 16, 2015 11:08 AM
chuck1177
Aug 11, 2015 03:22 PM
Wnthunting
Jul 9, 2015 03:02 PM
Mphillips
Jul 2, 2015 07:20 PM
