tire tubes to use with studs?
Old Nov 27, 2003 | 03:07 PM
Blaster2fast's Avatar
Default tire tubes to use with studs?
i gott an extra pair of tires id like to stud up for winter use... but iknow they dontl ast long when you do that... but what if i bought a tire tube? would that work??
Old Nov 27, 2003 | 08:37 PM
SuzukiZ250Kid's Avatar
I'm not sure that a tube would work. It all depends on what ya use for studs. If they penatrate the tire too far they might wear a hole in the tube also. In NY we used sheetmetal screws and then put something like "fix-a-flat" to seal up the holes around the screws. Didn't have too many problems with that.
Old Nov 27, 2003 | 09:08 PM
hmm
i think i will put the tube in it... for added saftey and slime my tire ... i was also thinking about using snowmachine studs... any seen those b4?
Old Nov 27, 2003 | 10:16 PM
I haven't seen anybody use snowmachine studs b/4. The sheetmetal screws work pretty good on ice until they get worn down.
Old Nov 28, 2003 | 09:28 AM
2000IAWarrior's Avatar
blaster2fast- what tires are the studs goin into i recommend just gettin 1/2 in or one 7/16in. studs do not put tubes in if one stud happen to go all the way through its gonna put a hole in the tube and u will re screwed.. just put slime in.. i dont like slime but if u are afraid of a flat then use it.. just makes a mess on ur rims
Old Nov 29, 2003 | 07:11 AM
my stock ones... they are pretty new still got the green line on them...
Old Nov 29, 2003 | 07:12 AM
ive heard alot of problems with pepople studding there tires though...goes through are they come out but the tire only last like less than a week...from people i know and what ive heard.. ive never actulyl done it.
Old Nov 29, 2003 | 10:48 AM
y would the tire only last w eek?
Old Nov 30, 2003 | 12:24 AM
newbeatle's Avatar
you definately don't want to use a tube... I personally use grade 8 bolts, from the inside... chopped off to a point, with washers... then slime... the ice studs will work fairly well, if screwed into the lugs & a long enough stud is used... again, with slime
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
black_thunder
Sep 20, 2015 10:21 PM
highwayman
Sep 19, 2015 12:59 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
