Steps for motor break in on a 720
Well it's assembled and in the frame. I did tighten the bolts that go in the staybolts (which hold the majority of the motor down) 2 pounds tighter. What do you guys recommend for the break in procedure for this thing. I want to keep the motor running as healthy as possible. Hopefully this weekend it will fire and then all I have to do is tune it.
Go to glamisdunes.net and click on the break in procedure, this is what I did and it worked great. A heat cycle is when you start the bike, let it warm up for about 10 min and then shut off and let cool. Put a fan on it to keep it from overheating, Kinda like riding but without a load on the motor.
Originally posted by: BartlettRacing
taking it easy is the worst thing you can do ....
think about it : When I was into stock car racing we used to build a motor ,slap it on the dyno and run it to its max !!!! 6,500-7,000rpm on a motor that never fired untill it was bolted on the dyno !!!!!!!!
