Steps for motor break in on a 720
Old Nov 29, 2003 | 01:11 AM
Entomber's Avatar
Default Steps for motor break in on a 720
Well it's assembled and in the frame. I did tighten the bolts that go in the staybolts (which hold the majority of the motor down) 2 pounds tighter. What do you guys recommend for the break in procedure for this thing. I want to keep the motor running as healthy as possible. Hopefully this weekend it will fire and then all I have to do is tune it.
Old Nov 29, 2003 | 01:16 AM
SANDMAN430's Avatar
just heat cycle it a few times and then ride hard.
Old Nov 29, 2003 | 01:58 AM
Entomber's Avatar
Forgive my ignorance.. but what is a heat cycle?
Old Nov 29, 2003 | 02:03 AM
Jerfinds's Avatar
Go to glamisdunes.net and click on the break in procedure, this is what I did and it worked great. A heat cycle is when you start the bike, let it warm up for about 10 min and then shut off and let cool. Put a fan on it to keep it from overheating, Kinda like riding but without a load on the motor.
Old Nov 29, 2003 | 03:32 PM
Squatcher's Avatar
I did the heat cycle thing and I took it easy for the first tank of gas. After the first tank let it rip.
Old Nov 29, 2003 | 05:23 PM
fast440's Avatar
I've heard that bartlett but I'm ont sure I believe it. I think changing your speed and gears often without going too hard on it is the best way
Old Nov 29, 2003 | 06:05 PM
PUSHINTHELIMIT's Avatar
Originally posted by: BartlettRacing
taking it easy is the worst thing you can do ....
Exactly, you gotta run them like you got a pair if you expect it to run at it's best.
Old Nov 29, 2003 | 07:07 PM
lilnotts's Avatar
after i put my new valves n rings in, i was kinda in the middle, wasn't babying it but wasn't pinning all the time either
Old Nov 29, 2003 | 07:26 PM
think about it : When I was into stock car racing we used to build a motor ,slap it on the dyno and run it to its max !!!! 6,500-7,000rpm on a motor that never fired untill it was bolted on the dyno !!!!!!!!
I'll say it again, EXACTLY! Just like the Nascar motors, they break 'em in by putting them on the dyno under a load and hold them to 8000rpm! And no one can't tell me they don't know how to do it right!
Old Nov 29, 2003 | 07:37 PM
BillDS650's Avatar
I like http://www.duncanracing.com
