Wider front end than rear
Old Dec 3, 2003 | 08:31 PM
absrio's Avatar
Default Wider front end than rear
If I go with +1 a-arms will i need an extended axle or will I be ok. Cause if you think about it +3 a-arms usually run with a +4 axle so theory extending the front by 6" and the rear by 4".
Old Dec 4, 2003 | 12:41 AM
440EX026's Avatar
Dont forget that most extended axles like the lsr axcaliber can be set to +2 or +4.
I run Houser +1 Lt fronts with the stock length axle and its just slightly wider in the front with 4:1 offset wheels without any problems. Do remember that not all a-arms are the same exact length either and this will change with MFG. The LT set up is actually +1.375 per side so the +1 is the accepted name tag but not the actual length etc.
You should have similar results since zuki pretty much just copied the ex frame anyhow [img]i/expressions/face-icon-small-smile.gif[/img] just bustin.
Old Dec 7, 2003 | 02:15 PM
thomez's Avatar
With +1 front you can buy narrower offset wheels 4/1 as mentioned and be almost stock width - another option would be wider offset rear wheels to get it wider a few inches....
Bratman2
Aug 6, 2022 01:42 AM
07Redrider400
Jul 25, 2015 05:31 PM
rcappie4
Jul 18, 2015 07:51 AM
tporath
Jul 11, 2015 12:31 PM
cSchwartz
Jul 9, 2015 02:40 PM
