wheel spacers
Old Dec 5, 2003 | 08:37 PM
z250freak's Avatar
Default wheel spacers
Are they any good. Do they work and would z400 ones fit my z250 because you know what they say, wider is better. What would be the best brand to get and are they durable. Thanks
Old Dec 7, 2003 | 01:50 PM
thomez's Avatar
I would not even consider them on the front of an ATV. You should spring for some cheap extended A-arms, spacers up front are bad.
For the rear, they are fine, as long as you aren't doing any big jumping. If you are, they may break, or increase the chances that your stock axle will break. For general use if you aren't putting them to too much pounding, I have heard the DuraBlue's are nice.
I imagine Z400 ones will fit your Z250 because of having the same bolt pattern. Check with the manufacturer to be sure.
Good luck! [img]i/expressions/face-icon-small-smile.gif[/img]
badgerboy1
Sep 26, 2017 06:11 PM
Oct 10, 2015 10:20 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
tysonbully
Sep 28, 2015 02:30 AM
r1pilot83
Sep 27, 2015 07:38 PM
