02 Raptor carb problems
Old Dec 7, 2003 | 06:28 PM
Kilapest's Avatar
Default 02 Raptor carb problems
About 1/8 throttle my carb starts backfiring, stumbling and dies. Stock except for GYTR pipe. Will run ok with the choke half on. I have takin the carb off many times and cleaned it. Anyone have any ideas as to what might be causin this? Thanks in advance.
Old Dec 7, 2003 | 06:39 PM
SOPMODM4's Avatar
check your parking brake lever on the handlebar, and the rear caliper. I bet it is the connection causing the problem. Do a search on here for Parking Brake, and see what you find! I could be wrong though!
Old Dec 7, 2003 | 06:53 PM
RoostItUp's Avatar
Your running to lean, bump up them jets! Did you ever rejet after you put the pipe on? Sounds like it starts in the needle/pilot I bet it gets even worse when it gets to the main and that's prolly where it's dying.
Old Dec 7, 2003 | 08:55 PM
Mr45auto's Avatar
will run with the choke half on? Check your carb boots also open the top of the carbs and see if one of your needles has popped loose. I had that happen once and it ran like crap. Pull the plastic covers on top and have a looksee.
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
need4aquad
Feb 4, 2001 03:26 AM
RaptorGuy01
Oct 31, 2000 04:23 AM
