rebuilding 250R forks
Old Dec 8, 2003 | 10:27 PM
MillerMad's Avatar
Default rebuilding 250R forks
i am trying to rebuild the forks of my 85 250R i got top cap off and the springs out, the dus seals out and the snap ring off but i can't get oil seals out, does the shock come further apart or what?
Old Dec 9, 2003 | 04:36 PM
Bulldog250R's Avatar
check the microfische on bikebandit.com- should give you a blowout view of all the parts in those forks. Havent had mine apart, so I wold be interested in what you find.
Old Dec 9, 2003 | 05:12 PM
AlkyBurninX's Avatar
There is a screw in the bottom that is about 2" long. I think a 6mm allen wrench is what you need to take it out. When you pull the tube out, there will be a split bushing on the bottom. Check this bushing for wear. Don't damage it!!!
Old Dec 9, 2003 | 06:29 PM
MillerMad's Avatar
I TRIED TO PULL OUT THOES SCREWS AND ALL MINE DO IS TURN THEY DON'T SEEM TO BE COMMING OUT
Old Dec 9, 2003 | 07:31 PM
thebutelr's Avatar
My manual for my 250ES says that you might have to get an air compressed drill to get it out. That might help.
Old Dec 9, 2003 | 11:35 PM
MillerMad's Avatar
YOU MEAN I WILL HAVE TO DRILL THEM OUT?
Old Dec 9, 2003 | 11:42 PM
thebutelr's Avatar
No NO NO!!! I meant that the damper rod turns inside the slider and you might need an air impact driver to get it out. Don't go drilling any holes! Sorry about that man, if you can't get it out with an air impact driver try and take it to a dealer and have them remove the screws.
Old Dec 10, 2003 | 03:47 AM
MillerMad's Avatar
Well how do i get the damper rod to stop turing inside the slider?
i tried an impact on the screw and it did was turn.
i really don't want to take the shocks to a dealer so any more info would be greatly appreciated
Old Dec 10, 2003 | 08:03 PM
250ex's Avatar
I've done mine so they do come out. I believe getting those screws on the bottom loose is the first step in doing the forks.
Old Dec 11, 2003 | 02:39 AM
MillerMad's Avatar
That may be i guess i'll put it all back together and try that?!
