04' Headlight mounting
Old Dec 8, 2003 | 11:58 PM
lilnotts's Avatar
Default 04' Headlight mounting
Well i'm putting in my new headlight, how do the brackets go? i have the top bracket behind the dash bracket, is that rite?
does all of yours fit right?
Old Dec 9, 2003 | 07:21 PM
lilnotts's Avatar
common, nobody can help me?
Old Dec 10, 2003 | 10:29 PM
BillDS650's Avatar
I just got my stuff tonight and I need to make a trip to the Hardware store this weekend. I need some screws and rubber grommets and a male connector for the power to the lights. lilnotts did you get the lower bracket that mounts off the oil tank.
Old Dec 10, 2003 | 10:51 PM
lilnotts's Avatar
i got everything for it, but its sittin on the oil tank a bit n i don't like that, thats y i was wonderin if i did it wrong or somethin
Old Dec 14, 2003 | 12:59 PM
BillDS650's Avatar
Still trying to find a 3 pin male connector for the head light.
Old Dec 14, 2003 | 05:43 PM
lilnotts's Avatar
well for wiring i'm just going to use 3 flat male spade connectors, but you could just find a 3 wire trailer connector and just chop the plug off and put ur own on,
Old Dec 14, 2003 | 10:46 PM
DSJOBBER's Avatar
I too put the 04 headlight on. I went through just about every type of mounting option before finally settling. I didnt use any type of adjuster screw. I just bolted the lighting on so that the light pointed the direction I wanted it to go. If anyone has any pics of the "stock" 04 healight mounting that would be great. Still seems like this headlight is not made specifically for the quad. Must have been leftovers from something else.
Old Dec 14, 2003 | 11:10 PM
BillDS650's Avatar
You can use all the old mounting hardware for the old headlight. The adjustment screw is a little long.
95wolv
Sep 27, 2024 12:00 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
PrairieDog126
Sep 16, 2015 01:33 PM
toonces
Sep 5, 2015 01:14 PM
