what rim sizes to run
Old Dec 10, 2003 | 04:30 PM
TrickyP's Avatar
Default what rim sizes to run
Does it make a differance if you are running a 10inch rim or an 8incher?
I do alittle drag racing and play around on MX tracks what should I run?
Old Dec 10, 2003 | 04:52 PM
PUSHINTHELIMIT's Avatar
A 9 inch rim is a good "all around" rim. An 8 inch "may" be better for MX if you're running 18 rear tires and a 10 inch rim "may" be better for harder pack surfaces and could be better for running bigger tires for less sidewall flex.... I say stick to a 9 inch rim for all around use.
Old Dec 11, 2003 | 09:43 AM
Hillbilly720's Avatar
When a bought a set of ITP 10x8's for the rear using 22 inch Holeshots the narrower rim squeezed the tire a bit and made it a hair taller and a little more narrow. Also the 10x8's gave me a rear width of about 48" while the stock 9x9's will give you a full 50". Both setups have their advantages and disadvantages. My favorite is the 9x9'x with a set of Maxxis 4 Snow's, unbelievable straight line hook up![img]i/expressions/face-icon-small-happy.gif[/img]
Old Dec 11, 2003 | 09:59 AM
sam's Avatar
sam
will a 8" rim fit on the rear of a DS, with the DS having such a large hub?
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
Levi Enstad
Sep 26, 2015 08:00 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
rgjackson
Sep 23, 2015 01:53 PM
Chasso
Sep 19, 2015 03:06 AM
