Banshee Transmission Oil
Old Dec 10, 2003 | 05:29 PM
DeuceRooster's Avatar
Default Banshee Transmission Oil
It's time to change the oil in my 04 Banshee's trans. Some people told me I should just use 10w30 motor oil, is this true?
What oil do you folks use?
Old Dec 10, 2003 | 05:50 PM
Buttermilk385's Avatar
I highly recommend Bel-Ray Gear Saver 80W oil.
I currently use this in two Banshees. Clutches seem to really like it.
I've also used Yamalube 4R, which also works well, but makes the clutch a bit more 'grabby'. When I've used the Yamalube 4R, the clutch didn't want to release when the lever was pulled in, causing the quad to creap forward. Switching to Bel-Ray Gear Saver 80W made this better.
One oil I used early on, when I first got the Banshee 4 years ago, was Castrol. I think I used 10w-40 petroleum version (not the synthetic or the synthetic blend - and I avoided the one that has the seal for the petroleum institute for gas saving, which has additives that are not good for the clutch - or so we're told). Never had any problems using the Castrol, but feel more comfortable with the gear saver oil.
80W gear oil is equivelent to 10w-40 motor oil with regards to viscosity.
Regards,
buttermilk
Old Dec 10, 2003 | 06:17 PM
ZBlaster's Avatar
Regards,
buttermilk
i also recomend it.
AlkyBurninX's Avatar
ran belray gearsaver for years. Recently changed to Motul Transol and love it. Easier to find neutral and clutch seems smoother.
Old Dec 10, 2003 | 10:33 PM
Okay thanks for the excellent information guys. I will probably go with either Belray or Motul depending on which one is easier to get locally.
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
shimanok2
Jan 29, 2016 07:37 PM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
