Razer 2
Old Dec 10, 2003 | 07:38 PM
BADASSS250RIDER's Avatar
Default Razer 2
I was wondering what kind of terain I can go through with these tires..They are pretty nice......
Thanks
Old Dec 10, 2003 | 09:26 PM
quadracer18's Avatar
Default Razer 2
Ya I'm debating on tires right now too...But from what I know..the raz'r can be purchased as four ply or 6 ply.. the raz'r 2 is made of a hard compound which is good in trail riding, and for rocks. It raz'r 2 is great for mud or really loose dirt...the tread pattern has a more open pattern design so it cleans out really good.. The only week link to the raz'r 2 is that it doesn't grip super good on packed dirt or hard ground were dust is covering that...But if you don't plan on doing much dragging or track racing then this tire is great for trail riding and really aggressive when it comes to mudd. Hope that helps a little
Old Dec 10, 2003 | 10:24 PM
Default Razer 2
ya i will pretty much be trail riding and riding in an open field that is rocks and loose dirt...Thanx for the info it helped alot....
Old Dec 10, 2003 | 10:53 PM
Fixitmatt's Avatar
Default Razer 2
I don't have the rears But, I do have the fronts and I can tell you that they are good for high speeds and turns.
However, if you ever get the fronts I wouldn't go with the stock size as they come big.
If you have a 23x7x10 front on now I would go to a 22 or even a 21 . I have had the 23s and they were so tall that the front of the quad was to high so, I went to a 22 and they were about the same hight as the stock tires.
I do not know if the same is for the back .
Old Dec 11, 2003 | 01:15 AM
jamag's Avatar
Default Razer 2
i disagree, the razr's suck in the mud.... i race a grandprix series here in mo. and last weekend our race was part mx track and part woods, the razr's work excellent in hard pack and or loose dirt, but suck in the mud, the track was real wet after a couple days of rain and as soon as the dirt left tacky and turned muddy you could fill the speed drop and i just started spinning and fishtailing around the corners, if you dont ride alot of mud i highly recommend the razr's if you havent ever riden with them, you have no idea how much traction you are giving up with the stock tires... a simple mod that has worked awesome for me btw, is i dropped to a 20x11x10 rear, and, wow, the torque difference that made, this little t.b. is now a tight woods animal, give them a try, you wont regret it
just my thoughts
james
bberck
Jul 29, 2006 09:50 AM
atvaddict01
Nov 4, 2004 11:39 AM
Crotts
Aug 20, 2003 11:58 PM
mojavekid13
Apr 7, 2002 08:33 PM
kkkiller300ex
Jul 16, 2001 10:43 AM
