Razer,Dominator,Bandits,or Realtor,whats the best???
I'am looking into buying a new set of tires!I just wanted to know which one of these are better.Razer,Dominator,Bandits,or Realtors!I mostly do trail riding with a little pit,and mud mixed in.Also i would like to know what size to go with 22'or 20'..All the info u can give me will help
Razrs all the way , They are awesome tires , realtors are too heavy for a sport bike.
Http://www.atvtires.com
They have the best prices on razrs that i have seen, the only problem is that his shop is in sackville.
i have a pair of bandits
and they are heavy but i havent noticed it since i got them on the power and stuff still seams the same
i love them they have big deep lugs and work great in anything from sad to mud to hardpack
i went with 20 cause i think it looks better but if you do you will want a bigger sprocket because it does slow you down quite a bit
the smaller tires also lower it tho i like because it handles better bit if you do alot of muddin or rock crawling loosing the clearance will suck
I had realtors and holeshots. My buddy has razrs. Realtors are pretty good, but they aren't the best trail riding tire. Kinda rough ride. But they are good in snow/mud. Holeshots and razrs are both excellent trail tires. My holeshots would always deflate. I heard that itp had some problems at first with a bad rubber compound, but it is probably corrected by now. The razrs are very similar to holeshots and wear really good. I also have had all-tracks. They are more aggressive than holeshots and razrs and are better for mud.
I think i will go with Razers,now i just have to deside wather or not to go with 20' or 22' i do mostly trail riding so what do u guys think i should go with.If i went with 20's i would have to change my sproket to a 41 right?
You don't have to change your sprocket if you go with the 20's. It may not make that much of a difference. I would ride it first and see what you think. If anything it will give you a little more low end which could be beneficial on the trails.
