Jetting specs for 2002 Scrambler 400 4x4
Old Dec 11, 2003 | 10:06 PM
speedydog5's Avatar
Default Jetting specs for 2002 Scrambler 400 4x4
does any one know the factory jetting specs for a 2002 scambler 400 4x4 2 stroke and also if anyone has a pipe on what are your specs I bought one from colorado and I live in Chicago much lower altitude want a ball park so I can rejet properly
Old Dec 11, 2003 | 11:35 PM
401's Avatar
401
Look under the seat and there should be a sticker with different settings.Do you still have the 34mm carb on it?I don't recall what I had in mine.I would think it would be close as is,given the altitude and cold climate,probably rich.It is easy to jet by reading the plug.
Old Dec 12, 2003 | 12:16 AM
Scramblerman03's Avatar
I use a 260 main jet with this pipe and the HPD airbox/K&N filter(240 with stock airbox). And the stock needle in the 3rd slot. And I'm pretty close to sea level here.
fordfaithful21
Dec 7, 2015 05:52 PM
atvcollector
Sep 8, 2015 05:11 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
byronman
Sep 6, 2015 06:34 PM
Brandon400
Sep 5, 2015 08:44 PM
