Lightening?
Old Dec 13, 2003 | 09:01 PM
badcompanyracing's Avatar
Default Lightening?
Is there anything I can actually cut off of the frame besides skidplates? Im lightening it to drag race and im wondering what can actually be cut.
Old Dec 13, 2003 | 09:27 PM
talonhawk's Avatar
Default Lightening?
Just some of the things that I've removed for weight:
battery & bracket = 15 lbs.
rear brake and all componets = 10 lbs
thats just a few of the heavy items but my 99TB weighs around 380 lbs
down from 440 lbs.
Old Dec 13, 2003 | 09:33 PM
Default Lightening?
how'd you cap off the brakes? I was thinking about doing that or splitting the brakes so i can do burnouts when i race asphalt.
Old Dec 13, 2003 | 09:39 PM
scrambler420's Avatar
Default Lightening?
what do you have for a machine?
Old Dec 13, 2003 | 09:43 PM
talonhawk's Avatar
Default Lightening?
Just go to your local hardware store and get the proper size
block off screw that will fit in the junction box. Remove the
line that runs towards the back and install the screw.
You will have to bleed the system!
Old Dec 13, 2003 | 09:48 PM
Default Lightening?
Thnx talonhawk. Scrambler420, I have a 01 scrambler 2x4. We've got it tore down right now and im bout to paint so i was just wondering wat i could cut.
Old Dec 13, 2003 | 10:25 PM
2manytoys's Avatar
Default Lightening?
Dont forget the starter, Front factory bumper, rear sprocket guard, lighter handlebars, lighten flywheel, lighter wheels, oil injection. This all ads up to great weight reduction.
Old Dec 13, 2003 | 10:26 PM
2manytoys's Avatar
Default Lightening?
OOPS and factory floorboards. Replace them with nerf bars.
Old Dec 13, 2003 | 10:29 PM
Default Lightening?
Weve taken all done all of that except the flywheel and thats coming. We also just cut the plate under the floor boardand only run foot pegs. Thnx tho.
Old Dec 13, 2003 | 10:35 PM
2manytoys's Avatar
Default Lightening?
Then if you have done all that you should be down around 350-360. Thats not bad at all for any quad.
