2001 Warrior Problems bogging backfiring
Old Dec 14, 2003 | 01:35 PM
jdulac's Avatar
Default 2001 Warrior Problems bogging backfiring
I just bought a 2001 Yamaha Warrior that is having running problems. It starts right up and idles perfectly. But once you hit the gas, even at a 1/4 throttle it bogs down and start backfiring. If you try to give it more gas it will just die out. I removed the gas and replaced the spark plug no difference. I checked the carb and everything seemed clean and within specs. Please someone tell me this isn't something bad.
I don't know how long its been sitting. And I may have jumped the gun. But i figured it was just bad gas, bad sparkplug or carb. needed cleaning.
Any ideas?
Old Dec 14, 2003 | 01:57 PM
jdulac's Avatar
Unbeleivable. I just did a search and found out about the parking brake rev limiter problem. That was the IT! Took the carb off twice for nothing. Yehaa. Thanks guys. I did move the jet needle down one notch, should i put it back to the middle?
Old Dec 14, 2003 | 03:02 PM
Crotts's Avatar
If you moved the clip down one notch you made it a little richer, which wont hurt to leave it there if it runs good.
Sjrpp
May 2, 2023 03:59 PM
Reactant
Mar 30, 2022 02:08 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Sjrpp
Jul 5, 2015 09:04 PM
