High temp on EGT
Old Dec 14, 2003 | 06:13 PM
Jerfinds's Avatar
Default High temp on EGT
I just got finished runing my DS around the block a couple times after getting my EGT working. Idle about 800, mid rpm's about 1250-1275deg, and full throttle at 1400deg. I know that is too high and quickly let off. I am using a 285 main, 95 needle fourth notch from top, and pilot drilled to .062in. I was told that the 285 was too rich, and to use a 270. What do you think, would a main that is too rich cause the temps to go up, gas exploding in exhaust. I am getting some poping coming off full throttle. Should I go up or down on main, I dont want to hurt it.
Old Dec 14, 2003 | 07:39 PM
Maddog419's Avatar
Hello Jerfinds:
You did'nt say what your plug looks like. thanks
later
Old Dec 15, 2003 | 12:10 AM
Jerfinds's Avatar
I'm running alky, so you can't tell by the plug. I will check though, I guess if it is lean it will look very white, not sure.
Old Dec 15, 2003 | 10:07 AM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
You cant tell on alky it sounds like she wants more fuel.
Old Dec 15, 2003 | 11:23 AM
95wolv's Avatar
Jerfinds,
Sounds like lean condition, high temps are from not enough fuel hitting the piston and combustion chamber to evaporate and dissapate some of the heat. Popping out the exhaust also indicates lean, but mostly in the idle circuit or pilot jet, try turning out the mix screw, if you have to go past 4 turns, you may need to go up on the pilot.
Old Dec 15, 2003 | 03:18 PM
Jerfinds's Avatar
Thanks for the help, thats what I thought too. I had the 300 main in before and it did run better that the 285, but I did not have the EGT in yet to check temps, nothing to compare too. I will go to a 295 and check again to see my temps. I have been reading up on jetting and have read that one size jut is equal to 50deg and one notch on needle will also change the temp 50deg. I'll post back with my results.
Old Dec 15, 2003 | 05:55 PM
SAMCOEDS's Avatar
i run a .65 pilot and a 320 main with the needle all the way up and it runs great i also have jetting for blends if you need them pm me i dont wish to give them on the board.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 17, 2003 | 01:10 AM
Maddog419's Avatar
Big Bump:
later
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
fredrikrosen
Sep 28, 2015 09:58 PM
r1pilot83
Sep 27, 2015 07:38 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
