boondockers nitrous system-does it require a closed air box?
Old Dec 14, 2003 | 11:51 PM
duneittilludie's Avatar
Default boondockers nitrous system-does it require a closed air box?
I am sure some of you are tired of questions about nitrous systems but if you know specifics about the boondocker system i would like your input.The addition of nitrous to my raptor is starting to sound like the best way to go as far as the best return on the dollar for performance.The idea of having to run with a closed air box doesnt sound interesting because i would have to figure jetting out again and i want to avoid that so if you have this system on your quad i would appreciate hearing how you set it up.
Old Dec 15, 2003 | 01:42 AM
wildchild660R's Avatar
Dune look at some of these photos. Looks like the answer to your question .... boondockers installation
Old Dec 15, 2003 | 10:31 PM
wildchild-Thanks and yes it looks like i do not need to run an enclosed air box with the boondockers.I am thinking with the way my raptor runs now with the few mods that i have adding nitrous should make it quite a performer.How is your raptor project going?
Old Dec 15, 2003 | 11:27 PM
Yes it most certainly will make your rappy more of a runner than it already is. As for my rappy project ...... I found that I need some more important things right now truck (hint hint)
Old Dec 15, 2003 | 11:35 PM
Well at least you have your priorities straight but i am sure you will get the raptor done the way you want eventually.Good luck on the truck search.
Old Dec 16, 2003 | 12:20 AM
Yes by next spring/summer the rappy will be somewhat built up.
EIF
Apr 20, 2017 07:15 PM
2many2ride
Sep 27, 2015 04:35 AM
BYC
Sep 25, 2015 02:10 PM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
cboler9
Sep 24, 2015 08:35 PM
