Rich/ Lean ?
Old Dec 18, 2003 | 10:50 AM
Coachmc1's Avatar
Default Rich/ Lean ?
Hey folks- Need some help. What does lean and what does rich refer to? Lean not enought fuel? Rich to much fuel?
I am new to the 2 stroke and need some help. I have a Scrambler 400 and the plug is black with oil. Do I adjust the air screw on the carb or adjust the oil injector?
I think on the air screw out is to lean and in is to rich, is that correct?
Old Dec 19, 2003 | 04:31 PM
Slacker1bob's Avatar
Rich is too much gas. If you are running rich, you have to put a smaller main jet in. You dont adjust the air screw or the injectors. I suggest finding someone who knows how to jet a quad and have them help you.
Old Dec 21, 2003 | 08:38 PM
dragracer789's Avatar
Is the plug black after you ride at low rpm levels for a while? mid? or just hi? if it is all of these then i would adjust the pilot jet, needle, and main jet
pilot- bottom end
needle- mid
main- top end
if your just getting into this then i would have somebody that knows what they are doing to do this because if it gets lean the piston will melt.
Dammar
Apr 20, 2016 06:03 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
bvolks
Sep 13, 2015 12:57 PM
Minimod
Sep 10, 2015 09:20 PM
