Rich/ Lean ?
Rich/ Lean ?
Hey folks- Need some help. What does lean and what does rich refer to? Lean not enought fuel? Rich to much fuel?
I am new to the 2 stroke and need some help. I have a Scrambler 400 and the plug is black with oil. Do I adjust the air screw on the carb or adjust the oil injector?
I think on the air screw out is to lean and in is to rich, is that correct?
Rich/ Lean ?
Is the plug black after you ride at low rpm levels for a while? mid? or just hi? if it is all of these then i would adjust the pilot jet, needle, and main jet
pilot- bottom end
needle- mid
main- top end
if your just getting into this then i would have somebody that knows what they are doing to do this because if it gets lean the piston will melt.
pilot- bottom end
needle- mid
main- top end
