Sprockets What is the deal up? down?
Old Jun 23, 2000 | 04:04 PM
THEXOTIC1's Avatar
I have a highly modded 300ex motor and when i bought the bike it had a 15 tooth countershaft sprocket and a stock 38 tooth rear sprocket. I went back to a 13 front becasue i wanted the chain gaurd. What size rear sprocket should i run in order to make the bike run like a 15,38 setup. I thought a 13,36 tooth setup would work. But then an Atv mechanic told me that i should be running 6 teeth sizes down on the rear to get the 15,38 setup. He said for every tooth up on the countershaft to go down 3 teeth in the rear.
So i was going to put a 33 rear sprocket on the bike but now i am confused. 33 is the smallest sprocket they make for a 300ex/250x so i cant use a 32 tooth sprocket. Thankx in advance
Old Jun 23, 2000 | 04:10 PM
Y2K300EX's Avatar
A 15 tooth front sprocket fits in there?? I suggest going to sidewindersprockets.com they have a sprocket ratio chart so you can see what is close to what you need. They can make you any size sprocket you need I think. With a 13,33 sprocket combo the ratio is .01 more than with a 15,38 sprocket combo so I think the 33 tooth would work good.
Old Jun 23, 2000 | 05:02 PM
409LongRod's Avatar
just do the math:
15/38=.394
13/.394=32.99=33 tooth sprocket
the 3 tooth on the back equals one on the from is a good rule of thumb
buddieboy
Dec 9, 2016 05:50 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
Sep 23, 2015 06:23 AM
merryman
Sep 19, 2015 03:15 AM
Sep 1, 2015 11:59 PM
