300ex exhaust
Old Jun 24, 2000 | 03:01 PM
Chris0007's Avatar
Just wanted to know which exhaust I should get for my 300ex WB- E series or IDS2 supertrapp? And what size jets? Thanks
P.S Sorry for the mess up earlier my little brother was playing in the forums
Old Jun 24, 2000 | 04:23 PM
Mike300EX-99's Avatar
I just put a Supertrapp IDS2 on my 300 last Monday, got to ride it yesterday morning. In my opinion this pipe is a great mod for your ride. I've only run it with 12 discs(top end) so far. It pulls the top end of the gears nice, especially 4th and 5th. It felt a little weak at lower rpm's. With 12 discs the bike was more responsive when you kept the rpm's up. I'm gonna drop down 4 dics and see what happens. I went up one jet size, to a 125, on the main. It needs to go up one maybe two more to richen it up. I'm running a K&N filter with the lid on. I have the quiet series model, but the cores are interchangable. I think you can pick up extra cores for around $50/60. It also comes with a headerpipe. Don't know anything about WB's, I do know about DG's, gobs of low end and real loud. Hopes this helps, Mike.
Old Jun 25, 2000 | 01:37 AM
Chris0007's Avatar
Thanks for the helpful info Mike.
Old Jun 25, 2000 | 02:04 AM
luckywilson's Avatar
Get one from Powerrolls it is cheaper and works. Now for the money headers only give you about 1 to 2 horsepower for $150.00 to 350.00. A 10 to 1 pistion will make a lot bigger gain for under $150.00 It is easy to do. Get a book 4 hours and you are runing.
Old Jun 25, 2000 | 01:10 PM
tater300ex's Avatar
I might be able to help with jetting. I run a DG RCM series (you know the loud one!)and a K&N filter with stock cover. I started with a 125 main and the plug was still a little white so I decided to go to what I thought would be too rich and put in a 130, read the plug and go leaner from there. Well it turns out the 130 burns perfect! I also ride at an altitude of about 1000 feet.
Old Jun 26, 2000 | 12:49 AM
Chris0007's Avatar
THANKS, LUCKYWILSON, TATER300EX FOR THE HELPFUL INFORMATION.
Pehter
Oct 3, 2024 11:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
cboler9
Sep 24, 2015 08:35 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
