wut wo waggie
Old Dec 26, 2003 | 08:53 PM
thebigshow's Avatar
Default wut wo waggie
i was drag racing today when i noticed my engine was pouring oil all over the exaust.it looked as though i might be getting 720 earlier than i thought,but after i got it pulled in it looked like the oil is coming from the valve cover gasket if not from the top of the valve cover.im going to take off the gas tank in the morning.is this a commen problem any of u have had or should i start gathing parts for the 720?
Old Dec 26, 2003 | 10:51 PM
PUSHINTHELIMIT's Avatar
Make sure the valve cover bolts are tight! I had one come out and got oil on every frickin thing including all over my riding pants! It just happend too.
Old Dec 26, 2003 | 10:55 PM
thebigshow's Avatar
thats what im hoping happend..............did it all happen at once or did it gradully start leaking........mine gave up like i blew the engine exept i still had full power.
Old Dec 26, 2003 | 11:07 PM
It all happend at once.... Big a$$ explosion of oil on everything. One of my valve cover bolts actually stripped causing it to pop right out. That would explain the explosion of oil.... Check for a stripped bolt.
Old Dec 26, 2003 | 11:09 PM
thebigshow's Avatar
hey thanks i apprieciate it..........thats exactly what mine did
Old Dec 26, 2003 | 11:11 PM
No problem.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 26, 2003 | 11:46 PM
thebigshow's Avatar
did u have to change the gasket?
Old Dec 26, 2003 | 11:50 PM
TyreSpinner's Avatar
No you probably won't...
did the bolt itself strip or did the casting on the motor strip?!?
Depending on which thread is toast... Will depend on how much trouble it will be to fix
Old Dec 27, 2003 | 01:41 PM
The threads in the head stripped out, so I just retapped it and used a different bolt. Not a big deal. The rubber gasket is reusable.
Old Dec 27, 2003 | 06:29 PM
thebigshow's Avatar
NOPE.........lol i wasnt that lucky...looks like i blew a hole in the top of my valve cover right next to where the oil ties in from the tank.
