How many teeth are on teh front sprocket of a stock 2004 400ex??
Old Dec 27, 2003 | 03:19 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
Default How many teeth are on teh front sprocket of a stock 2004 400ex??
really need to know ^^^^
Old Dec 27, 2003 | 03:34 PM
K_Fulk's Avatar
Should be 15, I dont think they would change it from the earlier years
Old Dec 27, 2003 | 03:38 PM
300exrider19's Avatar
15!!!!!!!!
Old Dec 27, 2003 | 03:41 PM
Speedy2222's Avatar
ok... also is it lose a tooth more speed and gain a tooth more accel
Old Dec 27, 2003 | 03:42 PM
K_Fulk's Avatar
No you got it backwards.
Old Dec 27, 2003 | 03:43 PM
Speedy2222's Avatar
so it's gain a tooth more speed lose a tooth less speed???
Old Dec 27, 2003 | 03:46 PM
K_Fulk's Avatar
Yup, 14 for aceeleration 16 for top speed.
If you do go with a 16 you would have to take off your stock case saver and get a aftermarket one.
Old Dec 27, 2003 | 03:48 PM
Speedy2222's Avatar
case saver??? oo the guard do u gotta do that with all of them??
Old Dec 27, 2003 | 03:51 PM
K_Fulk's Avatar
If you use a 14 you will have plenty of room with the stocker. Most aftermarket casesavers should be fine for the 16. I know my Baldwin Case saver works. Some other aftermarket ones may be smaller. Just don't run without one if your chain happend to brake inside cases are expensive to replace.
Old Dec 27, 2003 | 06:15 PM
markdb420's Avatar
I have a DG full exhaust and 16 tooth front sprocket. The stock case saver works just fine with a 16 tooth front. These mods allowed me to keep great acceleration, and allowed for a higher top speed. Top speed is still alot less than my 85 250r 3wheeler and acceleration is much slower from 3rd gear up, as compared to my ATC. My 400ex ranrich from the showroom floor and now it is almost perfect with the exhaust and sprocket I run now. It wheelies easier than it did with the stock pipe and stock sprocket. It is a great quad and I plan on keeping it when I get a 450R at some later time.
I wish that I could get the 450R as a 3 wheeler then I'd have one hell of a machine!
Reactant
Mar 30, 2022 02:08 AM
Gtsordo
Jul 13, 2015 10:38 PM
1966F100
Jul 12, 2015 03:08 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
jettman
Jul 6, 2015 12:16 PM
