Re-jetted, now it won't start. (Help please)
Old Dec 28, 2003 | 05:04 PM
Ole's Avatar
Ole
Default Re-jetted, now it won't start. (Help please)
I just jetted my 03 400ex for the first time. Now it won't start at all. I put in a 160 main with a 42 pilot, and took the choke out. Neddle in 3rd position, fuel screw out 3 turns. I put on curtis sparks x-6 and a uni filter with no lid. The gas is on,and the fuel line is on the carb. The kill switch is in the middle position. When I push the starter all is does is crank nothing else. Every time I check the plug it is wet. Should I try a new plug? Please help I don't know what else to do.
Old Dec 28, 2003 | 05:39 PM
dzzy's Avatar
Yes try a new plug for starters. You may want to check and make sure you have spark. Check your work, make sure you have everything plugged in and assembled properly.
Old Dec 28, 2003 | 07:50 PM
cals400ex's Avatar
try pumping the throttle 2 or 3 times before hitting the start button. then hit the start button without giving it any gas. most people can get their bikes started without the choke when using the 42 pilot, however in cold weather i still have to use the choke. a new plug might help.
Old Dec 29, 2003 | 12:19 AM
Ole's Avatar
Ole
I'll try that. Thanks[img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 29, 2003 | 10:10 PM
Kyperman's Avatar
NEW PLUG NEW PLUG NEW PLUG!!!!!
Scooter's Shop
Oct 9, 2015 02:09 PM
2many2ride
Sep 27, 2015 04:35 AM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
JDawg8309
Sep 12, 2015 02:24 PM
alzgarvin
Sep 11, 2015 08:53 AM
