WHAT WOULD YOU DO????
Old Dec 29, 2003 | 12:14 AM
polarisbear500's Avatar
Default WHAT WOULD YOU DO????
i just bought my 26" Mudlites on the c-series aluminums and put them on my 99 sportsman.(I LOVE IT BY THE WAY) only problems is the fronts rub the fender when the shocks get compressed or when i go through a ditch( the fender is rubbed right where your toe is pointing when you ride) what can i do to prevent this?????? any ideas-anyone had this problem? thanks in advance, PB 500
Old Dec 29, 2003 | 12:27 AM
Traildog's Avatar
Your not alone. All of us that have upgraded to larger tires have rubbing on the fenders. HD springs help, combine that with a lift kit and that should solve the problem. My semi-fix is a Wayne Gretzky (hockey puck cut in half) lift kit with HD springs. My total lift is approx 1 1/2" at the bumper but still rubs when it hits hard. An after-market lift kit will give you a 2" lift so less chance of it rubbing.
Old Dec 29, 2003 | 02:29 AM
Sniff's Avatar
I run 27” Blackwater X/Ts and Progressive springs with the preset at max. I have never heard the dreaded tire to fender grind and I ride very aggressively. It looks like I could easily run 28s with no problems in ride height. I’m assuming that the preset on the springs is protecting me. ......Just my 2 cents.
