Stupid Tree!!!!!!
Old Jun 25, 2000 | 04:48 PM
Hondapride's Avatar
Yeah I have a 1998 Honda Recon and I hit a tree.
And now my bike does not turn right, when I put the bars strait she just goes all over the place and nothing is broken.
What should I do??????
Any help is great
Old Jun 25, 2000 | 05:33 PM
trx430ex's Avatar
Sounds like you either bent a tye rod or snaped a ball joint.
With the quad on level ground, Grab the front and back of one front tire. Now wigle it side to side to see where the play is. There should be no play,
Play- =ball joint
No play- =bent tye rod.
And the tye rods should both be straight. If one is bent replace it and re-aline the front end. Check ball joints for play.
Old Jun 25, 2000 | 07:42 PM
Hondapride's Avatar
Yeah your right its the tye rod.
So when I re-ajust my tires sould I have toe in or toe out??
Old Jun 26, 2000 | 02:32 AM
snowshark's Avatar
When you adjust the tie-rods go toe out. The Recon already turns very quickly. If you go neutral or toe in, then it will turn even faster but may feel tippy or unstable when turning at high speeds.
I adjusted my Rancher, with the string method. I had hit a few stumps while riding & was out of alignment. I adjusted both tires down to 1/8 of an inch, yes the Rancher does turn really quick now, but I don't like it. I am going to adjust them back out to 3/8 of an inch.
Old Jun 26, 2000 | 10:23 AM
covert's Avatar
Hey snowshark... we went riding this weekend in a lot of sand. How much air should I have in my Recon tires to prevent bump-steering and also have good tracking in the sand and going uphill?
00 Recon
00 400ex
Old Jun 26, 2000 | 12:34 PM
snowshark's Avatar
Covert,
Try 6 pounds of air pressure in the tires. This really helps when trail riding.
MikeyBoyesq
Sep 22, 2015 10:02 AM
caveeagle
Sep 19, 2015 01:20 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Elkaholic
Sep 6, 2015 02:44 PM
