Scrambler Nitrous Question
Old Dec 31, 2003 | 07:46 AM
Trailburner00's Avatar
Default Scrambler tranny question
My buddy has a Scrambler 500 HO and he wants to add nitrous to his bike, but he doesn't think the tranny will hold up to the HP. He's already jetted, ported and piped the thing. Is there a heavy duty clutch he can go to? He talked about swapping in a 700 Sportsman clutch assembly, has anybody done this? Does anybody have a scrambler on the laughing gas (NOS) [img]i/expressions/face-icon-small-wink.gif[/img]
Old Dec 31, 2003 | 09:38 AM
Bubba297's Avatar
Default Scrambler Nitrous Question
He needs to add more weight to the primary clutch when running the NO2. It will add a lot more power and the clutch will be able to shift faster with more weight and not pull down the motor rpms. That will also keep the belt grip better. A good roller secondary clutch sure wouldnt hurt anything. And a good Kevlar belt. But with the better belt comes less clutch life. Just some thoughts,Bubba
Old Dec 31, 2003 | 10:04 AM
Thanks Bubba, I apperciate it.
Old Dec 31, 2003 | 01:06 PM
modquad's Avatar
I still think that would look trick....start to bog down just a bit in a mud hole, then unleash the button. AND DA MUD GOES FLYIN'!!!!!!! [img]i/expressions/face-icon-small-smile.gif[/img] Power baby! hehe
Old Jan 5, 2004 | 07:13 PM
1fastpolaris's Avatar
I am not sure, but I was told you need to beef up the bottom end if you nos it
Old Jan 6, 2004 | 12:41 AM
BigBadScrambler's Avatar
I also think you would have to mod the engine some. At least a better piston and rod, and probably the crank too.
Old Jan 6, 2004 | 01:45 AM
mudmaster250's Avatar
look at boondockers NOS kit. dirtwheels hit almost 100 mph with it on the pred, and that was in the sand, think about the pavement
Old Jan 6, 2004 | 08:02 AM
modquad's Avatar
Dennis of Bad Boyz of AZ had good luck w/ it on his 400. He might be a good source for answers for how it would be on the 500.
Old Jan 6, 2004 | 05:17 PM
mrh's Avatar
mrh
It will hold up just fine. You will need to adjust your clutching as mentioned previously. The stock motor will be fine for the amount of nitrous you will be adding.
fordfaithful21
Dec 7, 2015 05:52 PM
MooseHenden
Sep 6, 2015 04:24 PM
Logan Collins
Sep 5, 2015 08:03 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
DeFox500
Jul 26, 2015 06:32 PM
