takin the jug out for new years
Old Dec 31, 2003 | 01:10 PM
tbsleeper's Avatar
Default takin the jug out for new years
how can i tell if my cylinder needs to be bored when i take it off? plannin to take it out in a few days because i got some $$ for christmas and its time to buy the wiseco piston kit and maybe the chain tensor[img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 31, 2003 | 01:17 PM
trailrider500's Avatar
You have to get a micrometer and a telescoping gauge messure the bore vs the piston find the difference.. You will also need to find out if it has been bored before... Also if it is scored bad you may need to go even bigger.. Check ring end gap that tells a lot as well... Are you going to have Rick do it? If so i think he does all the guess work for you, just send him your stuff and he will bore it to the right size.. Or you could take your jug and piston to your local machine shop they can tell you how much bigger you will need to go and they can bore it for you..
Old Dec 31, 2003 | 03:35 PM
BADASSS250RIDER's Avatar
definitely get the chain tensioner if you are going to be jumping....
Old Dec 31, 2003 | 07:17 PM
2manytoys's Avatar
The easiest way to find out if you need a bore job is look for the cross hatches in the cylinder walls. If they are still all there then cylinder is ok. If you see worn spots then it either needs to be honed or bored. Only go .020 on the bore.
Old Dec 31, 2003 | 07:26 PM
tbsleeper's Avatar
i've taken the cylinder out before but i never looked to see if it needed fixing so im gonna do it sometime in the near future. i was fixing the brakes today and since i was looking for a spot were they were leaking from i had to take off the gas tank. so since i was in the area i looked at the spark plug and it was pitch black and really crusty and wen i tryed to clean it off i couldnt get the crusty black stuff off. is this bad???
Old Dec 31, 2003 | 07:45 PM
2manytoys's Avatar
If your plug is black then you are a little rich. The crusty stuff is normal. While you have the tank out you should take the head off and chech out the piston.
Old Dec 31, 2003 | 08:04 PM
tbsleeper's Avatar
too late my mom had to put her truck back in the garage[img]i/expressions/face-icon-small-disgusted.gif[/img] i'll take it apart again its not hard
JohnnySplat
Aug 6, 2015 12:07 PM
Mikesohio
Jul 26, 2015 10:51 AM
Bratman2
Jul 25, 2015 07:16 PM
baysport
Jul 23, 2015 11:37 AM
black_thunder
Jul 12, 2015 11:04 PM
