Bear Will Not Start
Old Dec 31, 2003 | 04:22 PM
BuckMark's Avatar
Default Big Bear Will Not Start
I have a '01 4x4 that will not start. I drained the gas thinking what I put in was old but it will still not start. It hits only once or twice in a five second starting try. It is like it is not firing at all. I am going to replace the spark plug next. It was running fine and then just would not crank. Any suggestions?
Old Dec 31, 2003 | 09:45 PM
JohnO's Avatar
Definitely try replacing the spark plug. My Cat 500i did the same thing. Was running fine, left it parked for a few days, and it just wouldn't start. Spluttered, popped, but wouldn't start. I replaced the plug, and it fired right up. Darned if I could see anything wrong with the old plug...
My 96 Bear, on the other hand, also quit running this summer after running poorly for a day, but it turned out to be crud in the carb float bowl.
Old Jan 1, 2004 | 01:14 AM
BuckMark's Avatar
New plug did the trick but the old one looked fine. Go figure, just a little black around the business end.
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
Mkp
Mar 28, 2020 03:50 AM
buckshit
Sep 24, 2015 08:49 PM
Bulls
Jun 7, 2015 12:55 PM
1000gade
May 27, 2015 12:37 PM
