Scrambler34mm carb on a 250 Tb?? Question??
You will need a intake manifold also had to use the needle jet and needle out of the 30mm carb because the mid range was too lean.
I got my manifold from Hpd. Also will need the brass choke fitting for the 34mm carb,the one off the 30mm is different size.
