TRX 200 Parts
Hi,
I've got a 1984 Honda TRX 200. It needs a major overhaul. Is there anyplace I can find parts for it? Especially a carb. rebuild kit and a gasket set.
Any help will be greatly appreciated.
Thanks!
Thanks!
the 83-85 200x carb rebuild kit will work for the trx it will have a larger main jet, pilot jet and a needle jet with more taper u also can get a universal exhaust, air filter, piston, and cams from powroll and denniskirk.com because the 84 trx can the same parts from a atc200x all except for the exhaust because of the unique bends in the pipe.
you can get a few things for it on bike bandit and cheapcycleparts.com. check out my pictures and you can see my 84 trx 200, never an issue and original tires! good luck with your rebuild and show us pictures!
1986Vmax540
Jul 9, 2021 09:53 PM
