is it ok to use gasket maker?
Old Jan 5, 2004 | 11:31 PM
400quad's Avatar
Default is it ok to use gasket maker?
i used gasket maker to seal my crank case cover. is that ok to do? i have yet to ride it. i still have to fill it up with oil after i wait 24hours for it to completely seal. i did not use much at all just a thin bead then i made sure there was only a little on with a putty knife so it did not goosh inside the case after i tightened down the bolts.
Old Jan 6, 2004 | 12:03 AM
420EX's Avatar
as long as you used it along with thegasket you should have no problems.
Old Jan 6, 2004 | 12:30 AM
400quad's Avatar
what i used was not designed to be used with a gasket. at least it said nothing about the use of anything other than the sealant. it is NAPA "gasket maker". its designed to create a gasket or rather a gasket seal rather than use a seperate gasket. thus that gasket i was asking about a night or two ago is sitting beside my atv rather than in it. i figure i can always use gasket remover if it is not good for atvs, then use the $13 honda gasket if i am forced to.
this is the stuff i used.
http://www.napaonline.com/cgi-bin/nc...&usrcommgrpid=
Old Jan 6, 2004 | 09:46 AM
dzzy's Avatar
Put the gasket in!! if you don't use the gasket where it is called for, you won't have the proper end play in any shafts, and you could have a binding problem.
Old Jan 7, 2004 | 12:43 AM
420EX's Avatar
BIIIIIIG NO NO, ALWAYS USE THE GASKET ALONG WITH HE GASKET MAKER, the only thing you should be using the gasket maker for is to seal a gasket, even if you ripped your old gasket, piece i back together and seal it with the gasket maker then placethe cover onthe egine case but push it on only enough for the sealer to make contact, let it set fr an hour, then tighten it. works like a charm.
Old Jan 7, 2004 | 01:18 AM
400quad's Avatar
i just used the gasket alone. it made a fine seal. so is it the norm for u guys to use the maker along with the regular gasket?
now i just have a leak from the bottom hose hook up going ino the case. i think i need a new seal for it. or do 400EXs have a really slow leak if you put too much oil in?
Old Jan 7, 2004 | 02:00 AM
oneten's Avatar
id just go pay like $10 for a brand new one from honda then you dont have to worry about it.
1ArmBandit
55
Oct 14, 2015 09:03 PM
tysonbully
Sep 28, 2015 02:30 AM
Minimod
Sep 10, 2015 09:20 PM
Minimod
Sep 10, 2015 08:03 AM
