Rancher Throttle Cable Slack
Old Jun 26, 2000 | 08:53 PM
Rancher4x4ESLuvr's Avatar
Do I have to do an adjustment on my Rancher's throttle cable?
Is it opening up all the way stock???
Thanks!
Old Jun 26, 2000 | 09:00 PM
86atc250r's Avatar
It never hurts to check....
Old Jun 27, 2000 | 05:37 AM
supertraprecon's Avatar
try it and tell us if works
Old Jun 27, 2000 | 12:30 PM
snowshark's Avatar
I adjusted my Rancher, and it is more responsive at the low end.
I adjusted my throttle cable out about 1/4 inch. Try it, you have nothing to lose.
400 miles & still no problems, well except the scratches
Old Jun 27, 2000 | 08:49 PM
lablover's Avatar
How do you adjust the throttle cable?
lablover
Old Jun 28, 2000 | 03:06 PM
snowshark's Avatar
To adjust the throttle cable, first pull back the black rubber boot located on your right handle bar. Then screw the adjuster know counter clockwise. I had to use pliers to break loose the adjuster. The cable could then be twisted by hand. I unscrewed the adjuster until there was about 1/4 of a inch gap between the handle bars & the adjuster ****. Now, take her for a test drive, & adjust again if neccessary!
Old Jun 28, 2000 | 04:12 PM
MuddyRancher's Avatar
You can actually adjust it out further. Keep adjusting until you hear the engine start to rev, and then let some more slack out until it is normal again. Then you will want to turn the handle bars both directions and make sure the engine does not rev up. Remember so all this in neutral!
Cummins Driver
Sep 11, 2019 01:22 PM
GregM
Mar 6, 2018 06:53 AM
Knackknack
Aug 19, 2015 07:45 AM
Ashley S
Aug 6, 2015 12:56 PM
Scottma518
Jul 16, 2015 09:19 PM
