Knocking when Frozen??
Old Jan 8, 2004 | 12:54 AM
Tyrann's Avatar
Default Knocking when Frozen??
Hey guys.. I had my 650 out for a run the other nite and got pretty dirty.. I thought I'd better wash what dirt I could off it before I put it in my shed. Also it was getting close to the freezing mark in temp outside... After about 3 days in the shed with cold tempretures outside.. I knew one of my tires was losing air so I pushed my bike out and jacked it up removing the front wheel.. I left the bike out all day and it was pretty cold out... So after I got my wheel fixed and was ready to put back in shed I put on my choke and started the bike up. It ran for about 2 min before it started to idle low and start to sputter.. I usually run over and shut the choke off and let it idle on its own... But this time it stalled and I had a heard time getting it going by playing with choke and holding throttle in.. When I got it going finally it started knocking something wicked!! I thought it was gonna throw a rod or something!! But soon as I touched the thottle it would go away.. then come back again... It did this for about 30 sec then cleared up and I drove it into the shed and lite the wood stove to thaw it out.. Would have the belt been frozen? What about oil pressure? I mean it didn't do this right away when it was first warming up for 2 min? Any body have any suggestions or had this problem? Thanks!
Old Jan 8, 2004 | 08:36 AM
trx450's Avatar
My guess would be a clutch related noise.
Old Jan 8, 2004 | 08:55 AM
newbeatle's Avatar
I agree with TRX450... probably sticky / frozen wieghts in the primary clutch...
Old Jan 8, 2004 | 09:16 AM
Tyrann's Avatar
Thanks for the input guys.. So is this a serious thing or just make sure its thawed out before I go riding?
Thanks again!
Old Jan 8, 2004 | 10:40 AM
therock's Avatar
I think it is the compression release weights sticking. Mine did that every other time I started it up whe new but went away. It was clearly not coming from the clutch cover. Not a muffled sound at all.
ac
Old Jan 8, 2004 | 10:51 AM
trx450's Avatar
therock--- wouldn't the bike start, or run funny with the compression release malfunctioning? I guess the noise could be found by listening thru a piece of vacuum or fuel hose, aka a stethoscope. My P-650 knocked like this, in the cold. My noise came from the primary clutch area.
Old Jan 8, 2004 | 11:08 PM
therock's Avatar
Yours may be different then. Mine was clearly not from that area.
Old Jan 9, 2004 | 12:28 AM
reds650's Avatar
if the knock comes from the clutch when it's cold it's the wear shoes they have to much clearance [0.0-0.04"is what you need to have]
the other noise [compression release??] goes away when you rev it up and does not come back
Old Jan 9, 2004 | 07:48 PM
Tyrann's Avatar
I'm coming up for service in about 10 hrs so I will get the dealer to check it out for me... I just hope something was froze like ice on the belt or something.. I'll make sure its defrosted next run out.. Thanks again..!
Tomtom86
Aug 7, 2024 07:40 PM
01ssls1
Sep 22, 2015 06:50 AM
merryman
Sep 19, 2015 03:15 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
