Here we go again...What mix and what brand for 99 Banshee?
Old Jun 27, 2000 | 12:40 AM
Holyman's Avatar
I just got my first ATV since 86. I need some help figuring out which ratio and which brand of oil I should be using. The previous owner said he used Yamalube @ 32:1. I'm not going to be racing it and there are no engine mods, just pipes and carbs. Compression is good. What (if anything) does the factory recommend?
I know this has been posted before but I couldn't find the posting. :-(
Old Jun 27, 2000 | 09:03 AM
fakie99's Avatar
i think the manual said mix at 20:1, but no one does this. you will have no problem mixing at 32:1, and any reputable brand of pre-mix oil will work. don't sweat it; this one's a no-brainer...
Old Jun 29, 2000 | 02:48 AM
Sanddude's Avatar
I use Bel Ray Synthetic and mix it at 50:1. Here is a tip, it is more dangerous to run it to rich than to lean. If it is rich, residue gathers on the top of the piston and will burn a hole right through it.
Old Jun 29, 2000 | 11:23 AM
scotch54's Avatar
I will make it simple for you. Buy 1 bottle of golden spectro and mix it to 4.5 gallons of gas. I did this with my 2000 banshee and it ran perfectly. It had lot's of power and the plugs were brown.
Old Jun 29, 2000 | 05:32 PM
Katos's Avatar
I agree, any good premix will do well for your needs. Just dont go down to the small engine shop and pick up "lawn boy special" two stroker oil!
For what its worth, my MC-1 at 50:1 mixed w/ 112 sunoco supreme has me happy w/ the results, though I am far from stock.
Good luck
Nate
Old Jun 29, 2000 | 07:28 PM
crezmedwn's Avatar
The mixing ratio would depend on the mods to the bike itself....as far as a brand, I would recomend Castor927, thats what I run in my banshee, but I run it 50:1 because of the engine mods. Of all the engines I have rebuilt and/or seen rebuilt, those who ran Castor were in the best shape and by far the cleanest.
Brandon King
'97 Banshee(too many mods)
Old Jul 1, 2000 | 08:21 AM
Holyman's Avatar
There are no engine mods, just carb work and Toomey pipes. Would you still go to 50:1?
Old Jul 1, 2000 | 09:31 AM
Katos's Avatar
As far as protection goes, I agree that the castors may offer more, but as far as being clean, well I do not agree. I ran Klotz BeNol, in my YZs that I raced, and thought that they left high amounts of residue on the power valve. (And yes, I run premium race fuel and my bikes are jetted perfect)
Anyway, with a topic like this, there will never be a good answer, since everyone has their own idea of what the best is, my advice is to go and try one, and in the fall when you tear it down, then you will know if its the right oil
`Nate
Old Jul 1, 2000 | 11:26 PM
H300F's Avatar
the shop that did my motor said to go 32:1 on my banshee. they said to go as much oil as you can until it starts fouling plugs. i run mine on 32:1
Old Jul 2, 2000 | 12:12 AM
87_250R's Avatar
i think Castor927 is what most of the pro racers use and it is what i use, but they use it there sponsors give it to them. there was a kawasaki that was smelled very bad (made me feel sick.) not shure what it was gas, oil, engine?
wendal
Sep 7, 2019 06:46 AM
EIF
Apr 20, 2017 07:15 PM
fredrikrosen
Oct 29, 2016 07:56 PM
fredrikrosen
Sep 28, 2015 09:58 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
